It is currently Sun Jul 05, 2026 6:48 pm
 Post subject: chevy luv hood scoops
PostPosted: Fri Aug 26, 2005 6:45 pm
i was in the market to build or buy a hood scoop for my luv...any one no where to get plans to make a scoop out of sheetmetal? any replys are helpfull thanx
FlatBedJessE
PostPosted: Sat Aug 27, 2005 12:04 am
On e bay there is a glass hood with a scoop. Have you checked it out?
PostPosted: Sat Aug 27, 2005 8:01 am
Ive seen prefabbed steel cowl induction scoops around. Cheaper than buying a whole hood and easier than making one. Then theres always the plastic or fiberglass ones you can epoxy or rivet on and mold in with body filler.
PostPosted: Mon Aug 29, 2005 11:26 am
LUVTruck.com's Cornholio
On my '78 I got a universal ''6 Harwood fiberglass cowl. I trimmed it down, pop rivited it on the hood, cut the underneath of the cowl induction and then I got body filler and molded it in. Turned out nice, but the only problem is that the body filler pulls away from the cowl and it looks like a crack down it, but then agian I took out all the support under the hood and it was a 4 pin pull off style hood. That made it flex a lot when I took it off and moved it around.
