It is currently Mon May 25, 2026 5:09 pm
 Post subject: 5 lug conversion
PostPosted: Thu Jun 30, 2005 4:30 pm
Can some one give me some info on how to convert front spindles to 5 lug? 8O
thanks 8)
PostPosted: Thu Jun 30, 2005 5:39 pm
best bet is to contact a good local machine shop and see if they will redrill your hubs to whatever pattern you want it and then if they'll install the studs.
PostPosted: Thu Jun 30, 2005 6:01 pm
check out http://www.luvrestoration.com
they have a 5 lug conversion.
neil
PostPosted: Thu Jun 30, 2005 10:23 pm
8) hey guys thanks alot for your help :D
PostPosted: Mon Jul 04, 2005 9:16 am
Luvtruck.com Wookie
at the moment i have a stock pair of rotors coming and i was wondering if they had enough meat to redrill to 5 lug. i have this s-15 rear end sitting here and i don't feel like having two spares.
i know just about anything can be done for the right price, but would they be safe?
TiLtEd wrote:
Boobies!!! :D
 Post subject: 5 lug bolt patterns....
PostPosted: Sat Apr 08, 2006 2:00 pm
Well, I did the Search thing here so not to add to multiple listings...
I looked into changing over the stock LUV rotors from 6 to 5 lug and the local Machine shop who does most around this area that came recommended said he wouldn't touch those rotors anymore.
He states after many successful attempts to do the change, that the Rotors eventually cracked! :x
I now have a link to a place that may be able to rectify this.
I will keep you posted on what I find out!
:smt024
72 L.U.V.
427 SBC-700R4
Mustang II front suspension
LUV perf parts manufacturing
My Devotion to Karl :
PostPosted: Sat Apr 08, 2006 3:46 pm
neil
LUVRestoration is closed!
1980 Chevrolet LUV stock 1.8L longbed
1980 Chevrolet LUV parts truck shortbed
1983 Suzuki Gs550 Sportsman
1989 Nissan King cab P/u <totalled> 4/1/06
1986 Full size Chevy P/U
1993 Volvo 850 GTL
PostPosted: Sat Apr 08, 2006 4:35 pm
neil
Did you happen to glance at the date of this thread... and neils post in particular?!?
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Sat Apr 08, 2006 4:42 pm
lol, my thoughts exactly
2002 Lexus RX300
1998 Honda Accord
1977 Chevy Crew Cab Dually
1954 Ford F100
http://www.yvtruckclub.com/forum
PostPosted: Sat Apr 08, 2006 7:27 pm
ill keep reseaching....
update: I found a local shop that may be able to help me.
I spoke with the owner and he wants me to bring the truck over and go over the spindle/rotor thing. They do many changeovers so I may be in luck!
72 L.U.V.
427 SBC-700R4
PostPosted: Mon Apr 10, 2006 10:38 pm
Japanese Redneck
thats probably the easiest way to do it... have your stocks redrilled. but wait till you get them back. the way its done is really cheezy. they drill right thru the bolts that hold your hub to the rotor. I was surprised when i got mine back from Moser way back. I couldnt believe that passes for a good job. If you have the money I'd REALLY consider the Aerospace kit its about 650 ish. but will give you superior stopping power over the stock LUV disk brakes.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Mon Apr 10, 2006 11:30 pm
LINK?
72 L.U.V.
427 SBC-700R4
PostPosted: Tue Apr 11, 2006 7:07 am
No I didn't but I sure should have.
1993 Volvo 850 GTL
PostPosted: Wed Apr 12, 2006 8:35 am
Check out my website.
I did it a few years ago, then sold them to someone on the board.
I have part numbers, and pictures.
you will still need a machine shop to drill the rotors.
here is a direct link http://home.comcast.net/~skyedivr/luvvega.htm
03Cobra
PostPosted: Thu Apr 13, 2006 9:37 pm
for $500 you can get new aluminum aerospace kit with new rotors, calipers, and hwdr. look em up on the web and call. aerospace components.
9.75 @138 496
luv to race
 Post subject: Re: 5 lug conversion
PostPosted: Fri Apr 14, 2006 5:54 am
thanks 8)
I did just as the member "luv4me" said to do it on his web site and it came out sweet don't change a thing and you can't fail Send me an email to tntdyno@premier1.net and I will send you back some photos of the way mine turned out
PostPosted: Sat Apr 15, 2006 10:31 pm
Japanese Redneck
http://www.aerospacecomponents.com/home.htm
Unfortunately i dont remember the part number. may have to call them to ask.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Sun Apr 16, 2006 5:59 pm
seems like they have good stuff...
72 L.U.V.
427 SBC-700R4
PostPosted: Sun Apr 23, 2006 10:35 am
Are Vege and Monza rotors interchangable? Monza rotors are already drilled for 5 x 4 3/4 smallchevy pattern.
