It is currently Tue May 26, 2026 1:05 am
PostPosted: Fri Mar 18, 2005 1:41 am
where do the wires go its a sony CD player I don't know where the ANT Rem max 0.1a(dark blue), ATT(orange w/ white stripe), Amp rem. max0.3a(blue w/white stripe) and ILL(orange). I have to wire this myself there was no prior radio so I need to what i need to run these wires to to get it work. I already ran the red wire to the Lighter and the orange to the battery and the ground. but the Cd player doesn't turn on but when you hit eject it will try to eject a cd. Please help thanx
PostPosted: Fri Mar 18, 2005 4:15 am
you have the wires wrong. the red needs to go to the ignition not the cig lighter. the cig lighter is a constant power wire, you will not be able to turn the stereo off.
tap into a ign wire with the red wire, run a ground, usually yellow is the color for the constant power. orange could be it, put a fuse on it and run it straight to the battery, possibly the cig lighter may work but it's a lower amp fuse and may not run your stereo.
the orange ill stands for the illumination. if you want your stereo lights to dim with your dash lights hook it up to the light switch, if you don't it doesn't matter, it will just stay at it's max brightness.
the dark blue is a antenna, no need for hookup
blue w/white stripe is a constant rem for a amp if your going to be running one. 3 wires to a amp- rem,power wire,ground.
not sure on the att but it's not needed for the stereo to work
as long as it's grounded, you have a ign source (red) and a constant from the battery it will work. btw, the reason there's a constant is to keep your memory, clock working, Make sure to put a fuse on it. if something happens and you don't, you'll blow the stereo
btw, what part of cincinnati are you in ? thats my hometown, hopefully i'm moving back someday. colorado sucks ! i lived right on the border of springdale and sharonville, went to princeton high school. that's a nice area. 8)
PostPosted: Fri Mar 18, 2005 5:43 am
Thanx for the reply But I figured it out. I blew a fuse.
PostPosted: Fri Mar 18, 2005 7:51 am
cool 8) if your not going to bypass the cig lighter put a larger fuse in there. i think it ran on a 10, put a 20 or 25 in there. i tried the same thing and after blowing a dozen fuses i put a larger one in there. once the cd player is on for awhile it'll get hot and blow :wink:
