It is currently Tue May 26, 2026 12:13 am
 Post subject: Rear window seal
PostPosted: Thu Feb 24, 2005 8:10 pm
Has anybody had any luck finding rear window or front windsheild seals ???? If you have could help me out??????
Thanks[/list][/code]
PostPosted: Thu Feb 24, 2005 9:31 pm
rear no. windshield yes. you can get them off ebay from express glass or call a local auto glass place and they can order them.
If anyone knows a source for the rear seals let me know too, plz...
Resident lurker
PostPosted: Fri Feb 25, 2005 5:51 pm
I think everyone is looking for a rear window seal........
If everybody grows up with high self-esteem, who is going to dance in our strip clubs?
What's going to happen to our porno industry?
These women don't just grown on trees.
PostPosted: Sat Feb 26, 2005 4:50 pm
The rear seal is fairly easy to get out without cutting it, unlike the windshield. You could probably pull one from a junkyard donor if you are careful. I've never had a need for new one, always just reused what I have in there already.
PostPosted: Sun Feb 27, 2005 11:02 am
True xl, except my last one had a slider and the lip is a bit wider so the window isn't tight using that seal. ( I do have one from another truck with flat glass though)
Resident lurker
PostPosted: Sun Feb 27, 2005 12:24 pm
Ah yes, many of the rear sliders probably don't fit the stock flat glass seal, including the factory slider. It sticks out the back of the cab almost an inch. I lucked out and got a slider from a donor with the seal that had come with it. I've also got another willing donor with a factory slider waiting for my current truck, good seal included. (at least from the looks of it)
If you are just working with flat back glass though, you could get a fairly good seal by watching the u-pull yards in your area for a truck to come in. If you find one with broken rear glass they might give you a heck of a deal on the seal alone. Maybe find a rollover truck and there is a shot the seal would live through even if the glass didn't.
PostPosted: Sun Feb 27, 2005 8:36 pm
Here is another example of a part that a lot of Luv owners need at one time or another that should be reproduced. I'd like to see New bezels and
pins for the door hinges.
PostPosted: Fri Mar 04, 2005 9:42 am
When I got my rear window, the yard cut the seal to get it out. They handed me the glass and I asked what about the seal. They're like, ohh, we just cut those out. So I told them that I needed it so they spent a few hours and found one off another truck that fit pretty good in mine. Couldn't tell you what kind, but it's gotta be something real close.
1980 Luv Mikado 4X4
PostPosted: Fri Mar 04, 2005 10:20 am
There's one one ebay right now, comes with the glass.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... AMEWA%3AIT
Chad
PostPosted: Fri Mar 11, 2005 6:56 pm
I pulled my windshield, and had no problem with the seal comming out. I did not cut it at all, just pryed up on the corner, slid in a wire, pulled it across the top and down the sides, then pulled the glass. I'm not touching the rear glass, but it sounds like a pain.
PostPosted: Fri Mar 11, 2005 8:13 pm
Umm... the rear glass is 10 times easier than the front! 8O
PostPosted: Fri Mar 11, 2005 8:42 pm
Done a front and a few backs and I agree with Tilted. Back is way easier...
Resident lurker
PostPosted: Fri Mar 25, 2005 9:20 am
I ordered a window weatherstrip sample from http://www.JCWhitney.com part # 81UB2497Y to see if it will replace the rear glass seal.SoffSeal sells door wheather strip part # 9004 if anyone is interested.
PostPosted: Fri Apr 01, 2005 6:15 am
I got the door seal from SOFFSEAL,they are just like factory ones.They are a good buy!$69.00 pair
PostPosted: Fri Apr 01, 2005 11:11 am
According to the description on their web site, they are glue on, can you verify if this is what they are and how they install?
Thanks,
Chad
PostPosted: Fri Apr 01, 2005 12:03 pm
Chad
$20 and no one bid?! OMGWTFBBQ?
PostPosted: Sat Apr 02, 2005 5:02 am
They fit in the factory retainer.The factory ones I removed had glue in some places.I guess they stated glue on because of the fact that some places around the door(sides) they do need glue.
PostPosted: Sat Apr 02, 2005 4:33 pm
Kewl, thanks for the updated info.
Chad
