It is currently Tue May 26, 2026 12:13 am
PostPosted: Sun Jan 09, 2005 4:58 pm
These compention Engineering frame rails and drop member?
frame rails no:C3060, drop member no:C3061
just wondering if it would be easier then making my own, so if anyone has ever used these, did they work out good for you? http://www.competitionengineering.com/catalog/CategoryDisplay.asp?CatCode=11005
 Post subject: tubbed luv
PostPosted: Sun Jan 09, 2005 5:29 pm
I tubbed mine ,but used the factory rails...........moved them in linr 9"on each side.
 Post subject: just tubbin it
PostPosted: Thu Mar 17, 2005 8:03 pm
Yeah thats the same ones we used.already had the 4-link brakets welded on but, chassis shop jigged it up from there brought it home measured200 times then cut & weld. anyway only prob weve had is the drop on the crossmember will somtimes barely hit when pulling on the trailer
