It is currently Mon May 25, 2026 2:16 pm
 Post subject: Headlight Adjustments
PostPosted: Fri Dec 17, 2004 2:03 pm
dose anyone know how to adjust the lights tore-direct the beam. my lights are all out of whack.one hits the ground a couple feet from my truck and another goes up in the air and dosent even touch the ground. my truck is a 76. :D
PostPosted: Fri Dec 17, 2004 7:18 pm
If the front structure is straight, headlight adjustments can be made by turning the adjustment screws at the headlights themselves. You can find them on the outer edge of each headlight. The side to side adjusters are at 3 o'clock on the drivers side and at 9 o'clock on the passenger side. The up and down adjusters are at 12 o'clock at all headlights (2 or 4 lights). The headlight shrouds have recessed areas that a phillips screw driver will fit to.
If the beams are drasticly out of alignment, you might want to check if the light assy's are seated in to housings correctly. If the truck has suffered some front end dammage, it may not adjust out.
