It is currently Mon May 25, 2026 12:39 pm
 Post subject: Torsion bar mod kit
PostPosted: Thu Nov 25, 2004 1:57 am
Hi folks
I was just wondering if anyone has heard of a kit to extend the lowering potential of the torsion bars.
I have wound mine all the way out and I still want to go lower.
If anyone can help me, especially if they are in australia please email me on craig.wilson@joewhitemaltings.com.au
PostPosted: Thu Nov 25, 2004 3:08 am
You could take off the arm and rotate the bar to the next position on the spline.
PostPosted: Thu Nov 25, 2004 11:35 am
LSX LUV Owner
do u have any pics of your truck? id like to see how low it is... id go lower but id rub like crazy then.
 Post subject: gettin low!
PostPosted: Fri Nov 26, 2004 1:02 pm
well on my luv i got 16x8 with a 55 series tire all the way around in im sitting pretty low i even took out the front bump stop and cut off like a quater inch!! click my www button to see!
PostPosted: Sat Nov 27, 2004 4:36 pm
Hey twist_of_fate,
What backspacing or offset are your front wheels. I thinking of getting 16x8 on my '75 but was concerned on the backspaicing I should use. How much does you front tire stick out of the wheel wells. Any rubbing?
Thanks for the info in advance.....
