It is currently Mon May 25, 2026 8:26 pm
 Post subject: Alt. question
PostPosted: Sat Sep 25, 2004 1:57 am
So I just completed my V8 swap and I have evrything wired up[thanks D.] but the Alt. so I am not charging. Dennis brought over some copies of the article about Altenator swappin from here, but it doesnt say anything about removing the stock regulator. So my question is to those of you that have V8's. What do I need to do, or remove or whatever to get my truck to charge. THANKS AGAIN!!! T.
PostPosted: Sat Oct 09, 2004 1:34 am
Well figured it out, and to those that are in the process of doin a V8 swap, heres a little tip. Don't get the altenator with the built in regulator, Get the 1 wire Alt. { a 67 nova is the one I got } with no regulator. Wires right up, and you don't have to tear anything up.
PostPosted: Mon Oct 11, 2004 11:16 pm
Thanks for the tip!
One more (now how the hell am I gonna rig that up to work) head-scratcher's off my list!!
Lookin for another one.
PostPosted: Fri Oct 15, 2004 7:53 pm
I used the integral regulator type GM alt.On the 2 prong plug you run the red wire to the battery terminal on the back on the alt.Then just hook up your battery wire from your harness and take out the regulator. I had the ext type alt before and had problems later on. A old time mechanic showed me how to fix the earlier problem. Mine has been like that for over 15yrs and no problem
