It is currently Tue May 26, 2026 12:04 am
 Post subject: Front shocks
PostPosted: Tue Jul 23, 2002 10:49 am
Does anyone happen to have their front shocks out of their LUV truck? I need to know the extended length, and compressed lengths.
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
PostPosted: Tue Jul 23, 2002 1:40 pm
Aack! Just had mine out last week.
If at first you don't succeed, try it like your wife told you to do it.
 Post subject: shocks
PostPosted: Mon Jul 29, 2002 10:04 pm
i am looking for 90/10s and i found out that stock are compressed are 9.5 inch and extended
are 13.5 inch.summit has 90/10 but the luv is not on the list the closest
are 9.0 and 14.0 they will work good the 14.0 will let the ft end come up a little more than stock the part # is SUM-g7600 26.95$ each iwill let you know how they work wheni get them on my truck
 Post subject: 90/10 shocks
PostPosted: Tue Jul 30, 2002 6:19 pm
use any set of 90/10 shocks foe a 1969 camero, all you have to do is cut off the frame mounting tabs and your there. Pretty close to factory length.
PostPosted: Sun Aug 04, 2002 9:10 pm
Cool! Thanks for the info guys!
63 Nova
74 Camaro
PostPosted: Mon Nov 11, 2002 11:38 pm
4linkluv, how did the shocks work out... I have to get new front shocks for my 77 and am trying to figure out what to get.
 Post subject: Front coil over shocks
PostPosted: Tue Nov 12, 2002 10:21 am
I have had very good luck with them. The hard part is getting them ballanced out with driver so it does not wiggle down the road.
PostPosted: Tue Nov 12, 2002 11:16 pm
Paradox i do not like the summit 90/10 shock when i get some money i am going to get the Lakewoods ,the summit shocks should be three settings90/10-80/20-70/30 but all three feel the same,i called and got told that you cant tell off the car {i think they are blowing smoke }oh well live and learn i guess .hope this helps.
PostPosted: Tue Nov 12, 2002 11:20 pm
Paradox.sorry i should have asked if you are drag racing ! because 90/10 are not to street friendly, for the street i would run a KYB gas very -very good street shock
PostPosted: Wed Nov 13, 2002 12:34 am
thanks for the heads up... I will probably use the kyb's. That is what I have in my beatle.
 Post subject: I used shocks from...
PostPosted: Thu Nov 28, 2002 9:49 am
Japanese Redneck
I used shocks from my 1966 Nova. they were Comp engineering 3 way adjustable 90/10 70/30 50/50 and bought a shock extender kit from Jegs High Performance. shocks are like $25-30 each and the shock extenders were like $15. but if Camaro shocks are longer then i would just go buy them and skip the extenders. I run them set at 90/10 on the street all the time with no problems.
 Post subject: Lifting a luv for cheep
PostPosted: Fri Dec 20, 2002 7:42 pm
I just bought a 79 luv for $200 and would like to have some sugestions on how to lift it for cheep. A friend of mine sugested taking the rear axel and mooving it so that the leaf springs sit on top of it rather than under it. Is this a good ideah? Any sugestions on the frunt? :lol:
