It is currently Tue May 26, 2026 2:53 am
 Post subject: HOT FUSES
PostPosted: Fri Oct 08, 2004 10:13 pm
Well I finally got my charging system straightend out, and while doing this I noticed that a couple of my fuses were so hot that one actually had like solder drippin out of it. What would make the fuses get hot like that??
PostPosted: Fri Oct 08, 2004 11:22 pm
It sounds like either a short somewhere, or too small a fuse for the current being drawn.
77 2wd - Back on the road
05 Ford Five Hundred
 Post subject: hot fuses
PostPosted: Sun Oct 24, 2004 1:00 am
well i can answer that one for you. I do electronics for a living and learned early that glass fuses tend to oxidize as well as the contacts in the fuse box. This ends up causing a high resistance connection between the fuse and the fuse holder. As we all know resistance equals heat and the fuses will heat up to the point that the solder melts. To fix this problem replace the fuses with new ones and burnish the fuse contacts with a barrel brush for cleaning a rifle (the metallic kind). I'm not sure what caliber works best for this, the one I had was laying around in a junk box. This should take care of the hot fuses. Althogh a short or large current draw would cause this too, in theory it should cause the fuse to melt as long as the fuses have not been replaced with larger ones. I hope this helps you, the ultimate fix would be to replace the fuse panel with an ATC blade type but of course that means rewireing. :D
PostPosted: Sun Oct 24, 2004 1:08 am
Thanks Doc, I will give it a try and let you know how it goes!!!!!
PostPosted: Sun Oct 24, 2004 8:58 am
That advice almost sounds familiar... Do you still have the bore brush I brought over? If not let me know...
BTW 5.56mm/.223 works pretty well
Resident lurker
PostPosted: Sun Oct 24, 2004 10:21 pm
Um, Um I no Habla english :lol:
Users browsing this forum: Bing [Bot] and 29 guests
