It is currently Mon May 25, 2026 2:26 pm
 Post subject: sanding and primering Q
PostPosted: Mon May 31, 2004 1:36 pm
used to live at Luvtruck.com
hey all - another question :D
I wanna sand and primer my luv, so my question is, do you all have any tips or techniques to help me out?
thanks!
I got my LUV!!!!!!!
PostPosted: Mon May 31, 2004 2:24 pm
After just doing some touchup work on something a while back, I think the best tip is to get some power tools involved. Even a cheap random orbit sander will make a huge difference in time compared to the hand sanding block. Once you get through the coat(s) of paint on the big areas and start working on anything smaller then it makes sense to use the more careful touch of hand sanding. Someone who has done a lot more of this than I may have a good recomendation for the right tools at each stage, but I think just starting out thinking with some power tools involved will save a lot of arm work. Unless you are looking to get a good arm workout that is, you can build up some good tone working a sanding block. ;) (Wax on, wax off!)
The trick with power tools is to learn their pace quickly. You can move through paint fast with them, but also move quickly through metal that doesn't need to be taken off. Knowing when to stop is the key.
 Post subject: sanding tip
PostPosted: Mon May 31, 2004 4:13 pm
Get a cheap electric PALM SANDER like from walmart.Cost about 15 bucks.
PostPosted: Mon May 31, 2004 6:56 pm
Like luvondope Ive been using a palm sander also. Been doing paint and body work for around ten years and wish I wouldve bought it sooner. It sands flatter than an orbital and is alot cheaper.
PostPosted: Mon May 31, 2004 7:01 pm
Been using a Palm Sander for a while, I think I am going to switch up to a orbital though for the rough work, then use a palm for the fine stuff. But for the hard to reach places you still have to block it.
PostPosted: Tue Jun 01, 2004 8:00 pm
cool I've got a palm sander, so it looks like I'm set. wooo I can't wait to get started this weekend! thanks for the replies
I got my LUV!!!!!!!
PostPosted: Wed Jun 02, 2004 8:37 am
You all will be mad at me but I picked up a 10" orbital Sander/Polisher at Lowes last night on clearance. For $17.
