It is currently Mon May 25, 2026 4:10 pm
 Post subject: hot problem
PostPosted: Wed May 12, 2004 8:01 pm
ok bros,,i was told that a mor electric water pump with a good griffin radiator was ALL i needed to keep this 460/732 hp slightly cool....wrong.since i have no room for a fan in front of the water pump/ this 5.74 1/8th mile beast is getting hot......where can i install a fan or any suggestions.ty....bromwell@verizon.net.....
434 pushing 732 hp with no spray!!!
PostPosted: Wed May 12, 2004 8:20 pm
I've got an electric pusher on the front of my rad. works pretty well.
Resident lurker
PostPosted: Wed May 12, 2004 11:03 pm
rig up a thermo on the other sideof the radiator, behind the grille :D
PostPosted: Thu May 13, 2004 3:45 pm
bro did you say you have a electric pusher on the front of your radiator?i have my trans cooler their.........is there enuff room?when you say front .you meant front view correct?where did you get yours?ty.tired of over heating problems..... :(
PostPosted: Thu May 13, 2004 5:38 pm
Put an elec pusher fan in front of the radiator, and move the trans cooler to a remote location with a small elec fan. You can get a cooler/fan combo through many nationwide auto shops.
PostPosted: Thu May 13, 2004 7:39 pm
Yep, pusher is between the grill and radiator. The valance is notched cause the fan is a little thick. You could probably get a thinner one. Just make sure it will move alot of air. As for the trans cooler, mine is under the bed with it's own small electric fan.
You can get the fans pretty much at any parts store, or from JC whitney, jegs....
I've had one that was themostatically controlled and one on a toggle. I must say I prefer the thermostatic one, I've had a couple of close calls from forgetting to turn it on. :roll:
Resident lurker
PostPosted: Thu May 13, 2004 8:03 pm
thanks .actually my heating problem was .as to be expected with 4.88 /5500 stall.......732 hp on street...but after adding mor electric water pump and big griffin radiator,went via the roof...well my luv is tubbed ....running 32 x18 tires and moving the tranny cooler in all honesty is not an option.no room /truck sits low for launching with 4 link and with 3.5 stainless steel exhaust =which they practically are 2 inches at most from the ground.... :(
PostPosted: Thu May 13, 2004 9:31 pm
got pics ??
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Fri May 14, 2004 12:57 am
my ute is a manual so i dont need a trans cooler 8) so i have pleanty of room
PostPosted: Fri May 14, 2004 7:42 am
I have seen guys mount their trans cooler as an actual part of the hood. they cut a square out and put in what appears to be a small cowl induction scoop to allow the air to pass through without forcing water or junk down in it while driving. If you have a remote batt location, you could do this above the stock batt location (again with a small elec. fan). Just make sure to give yourself enough hose to allow for opening of the hood, or you could do pretty much the same thing except put the mount as part of the engine compartment and have it sit flush when the hood closes, having the cooler at hood level.....
PostPosted: Fri May 14, 2004 10:08 am
im going to mount my tranny cooler under the truck. my buddy has done this and it seemed to work fine. I will be monitoring it with a temp gauge.
I will let you peeps know how it does when I finally get it on the road.
03Cobra
PostPosted: Sat May 15, 2004 8:28 pm
Lookin through Jegs catalog, they have a frame rail trans cooler. Narrow and long, might be something to look into...
Resident lurker
