It is currently Mon May 25, 2026 2:26 pm
 Post subject: Front end stuff
PostPosted: Tue May 04, 2004 12:31 pm
ok where can i go to get new ball joints, tie rod ends and bushings and any other item i need to rebuild the front end? it is factory from 75 and it is a little shaky and i am scared to get it going to fast before i get that stuff replaced.
PostPosted: Tue May 04, 2004 5:55 pm
You can still get tie rods, ball joints, and stuff like that from most autoparts stores. I've never replaced any bushings in my LUV so I don't think I can help you there, but I imagine you can get some of those from parts stores as well.
A word of advice though, the upper balljoint on the LUV is held on by one huge nut. I have seen some upper balljoints come with this nut, but the ones that I bought did not. Since mine were rusted I had to cut them off and have new ones made. It was expensive and not to mention a pain to find a guy that was actually able to do it. You might want to do a little research and find out which ones come with the nut in the box so you don't have to go through what I did. At the worst just make sure you take the extra time to get the nuts off in one piece.
PostPosted: Tue May 04, 2004 7:12 pm
go to autozone.com
it's cool on there site cause what the guys see in there computer is what you see on there site. you just type in your car and what you need and it will show the same thing the autozone guys see, it's cool cause you can check on all the parts and prices :D i have the site bookmarked to my favorites. it's cool to just go on there and check out what they got and they actually have alot of info :D check it out man :D
PostPosted: Wed May 05, 2004 5:08 am
hey that is sweet! I never knew that!
thanks bcg!!!!!
03Cobra
PostPosted: Wed May 05, 2004 6:57 am
yeah when i went on the site i was like COOL. now you don't have to call to find a part. the best thing is, you type in your zip code and it'll tell you if it's in stock or special order at you nearest autozone :D :D 8)
