PostPosted: Tue Oct 29, 2002 2:30 pm
somebody knows trick to raise the front suspension with no need to change nothing... I have the torsion bar in the high position.....
PostPosted: Mon Nov 04, 2002 11:19 pm
well something you will have to check is the presure on you strut bars (if this is too much then you WILL break stuff, im doing this same thing to my luv) and if you need more hight you should be able to pull the torsion bars out and relocate them so you can cranck them up farther. I cant realy explain the procidure but a good shop maual should be able to tell you how to do it. If you can find it just drop me a line and ill try to post that section of my shop manual. Good luck!
