It is currently Mon May 25, 2026 10:06 pm
 Post subject: 29" swampers
PostPosted: Thu Apr 22, 2004 9:46 pm
hi will 29 inch swampers fit onto a stock luv with a 3" body lift? i dont want to do a hole lot of cutting on the body though!! if anyone has pics of a luv with a 3 inch body lift and 29 swampers i would appriciate it if you could send it to me!!!or post it on the forum so everyone can see it!! THANKS
PostPosted: Sun May 29, 2005 9:46 pm
yea i wouold think that they would fit,i dont see why they wouldn
PostPosted: Mon May 30, 2005 12:00 am
i would check out Narcist's(sp?) luv. he has a 3 inch lift and some bigger tires (not sure of exact size) and he had to do a lil cutting on the fenders.
send him a pm. or with any luck he will catch your post.
PostPosted: Mon May 30, 2005 11:08 pm
I've got a fixer upper truck here with 31x10.5 tires on it. It has 3 inches of body lift, and probably near that in suspension lift. The tires still rub fairly badly when turning. I haven't driven it on the road, but the prior owner said he had to go easy entering/leaving parking lots. The front fenders show the signs of it behind the tires too. You can cut quite a bit behind the tires without changing the look of the truck though. If I ever decide to make anything of that truck I figured to take a bit of metal off and make those 31s fit.
