It is currently Mon May 25, 2026 11:30 am
PostPosted: Fri Apr 02, 2004 2:55 pm
Here are my options for front wheel size, I'm having a hard time trying to figure out if they will fit. What do you think?
size Offset BSM
18x8 +14 mm 5.00
18x8 +27 mm 5.50
Does this mean anything to you? I'm not real familiar with figuring this stuff out. Also keep in mind that the inner fenders will not be there, so there won't be any rubbing issues.
I'm trying to figure out if they will sit inside the fender enough to tuck, if I were to body drop the truck 3 or 4 inches.
Any advice would be appreciated, I'm lost here.
PostPosted: Fri Apr 02, 2004 9:16 pm
you would prob be better off with the 18x8 14mm
cause if you tuck to far into the well you will hit the frame
