It is currently Sun May 10, 2026 3:09 pm
 Post subject: Suspension Lift
PostPosted: Sun Mar 21, 2004 1:18 pm
Has anyone here lifted their truck by the susrension? If not I think i found a way to get about another 3" out of the suspension. Will keep everybody informed if it works.
PostPosted: Sun Mar 21, 2004 5:39 pm
i think the only way to lift the front stock suspension is to crank the torsion bars. rear can be done a number of ways, like shackles, blocks, and new springs
i think the end all is to put a straight axle under the front though...
PostPosted: Sun Mar 21, 2004 6:08 pm
If your seriously thinking of doing some chewing with your truck, the best way is to do a straight axle conversion. That way you can put A LOT of lift under it, without having to deal with an IFS set-up. The torsion bars are good for a few inches from stock, and then a lot of guys cut the fenders out a bit to get some extra tire clearance under there. The back rear axle is easy to lift, the front involves more work. If you want a nice off roading truck in the end, do a straight axle conversion, get a toyota front, and bolt er in. Oh and if your cranking your torsions up, DO NOT crank them to full, back them off a bit, you lose ride height, but at least your not going to break the torsion bar off. :wink: Just my .02 cents.
 Post subject: lifts
PostPosted: Sun Mar 21, 2004 8:23 pm
I think that I have found a way to lift the stock suspension about another 3" or so. It will take some work to get the front up there but i will find a way.
 Post subject: lifts
I think that I have found a way to lift the stock suspension without shackles about another 3" or so. It will take some work to get the front up there but i will find a way.
PostPosted: Thu Mar 25, 2004 7:35 am
Are you just going to flip your springs over your axles?
GOT LUV?
Users browsing this forum: Bing [Bot] and 14 guests
