It is currently Mon May 11, 2026 2:51 pm
PostPosted: Mon Feb 16, 2004 6:47 pm
I'm going to install a 2'' lift on my 75 chevy luv and I don't want to cut the fire wall for the steering column, I was thinking of using the u joints, like they have on the trooper but don't know where to get them to do this. I would need two of them because I need to cut the steering column shaft at one end and use the one from the trooper at the other end. Has any one else done this? Maybe some one has a sketch or diagram of it? Or maybe a better idea on how to go about doing this so I don't have to cut the fire wall to drop the steering column two inches like the lift kit instructions suggest I do. Also my truck has an 80 4x4 chevy Luv frame under it, and I need better ideas on the floor shifters so they don't hit the floor boards. Thanks in advance. Matt
PostPosted: Fri Feb 20, 2004 10:43 pm
i have 3in lift and didnt cut my firewall.
PostPosted: Fri Feb 20, 2004 11:27 pm
my 80 luv has a 2" lift and the firewall is cut, but you can't tell unless you look real close. it also has a spacer under the dash for the steering column, but the column fits right up against the dash. you can't notice unless you look under the dash.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
 Post subject: 2' lift
PostPosted: Sun Feb 22, 2004 10:31 am
thanks for the help, I found the u-joints I needed for the the steering column now on to the rear bumper .........thanks again matt
