It is currently Sat Jun 13, 2026 12:01 am
PostPosted: Sun Aug 01, 2021 10:04 am
Anyone know if there is a good Wiper fluid container replacement? The motor that pumps the fluid is still good, not sure if I can use that with an aftermarket container.
PostPosted: Sun Aug 01, 2021 9:33 pm
Not sure if you are looking to buy something new from a different application to fit the LUV truck or just wanting a replacement. There are several used units available at www.car-part.com, hope this helps.
PostPosted: Mon Aug 02, 2021 5:41 am
Do you know if the 1st gen LUVs used the same as 2nd?
PostPosted: Mon Aug 02, 2021 5:13 pm
There's a guy on the FB page that has new ones with the motor/pump in Thailand. I think around $100 plus shipping.
PostPosted: Tue Aug 03, 2021 2:44 pm
Aged Luv wrote:
Not sure if you are looking to buy something new from a different application to fit the LUV truck or just wanting a replacement. There are several used units available at http://www.car-part.com, hope this helps.
It be nice if they still made a new fluid container. I checked out the site, looks like parts come from wrecking yards. Most of the ones in wrecking yards are aged and cracked. I saw in a different forum that some people used a 90 Toyota 4x4 fluid container. They had to drill a hole to firewall, but it went in ok. I just doing research for now. =)
PostPosted: Thu Sep 16, 2021 4:06 pm
I just replaced mine with a Dorman 54002 Coolant Recovery Kit. It was around $20 at Autozone.
76 LUV
PostPosted: Fri Sep 17, 2021 11:42 pm
Sorry, this is the one I used.
Universal Car Windshield Washer Pump Washer Fluid Reservoir Bottle Kit with Pump Jet Button Switch KEMIMOTO 12 V Windshield Tank compatible with Polaris RZR Ranger General.
76 LUV
PostPosted: Sat Sep 18, 2021 12:37 am
Here is another option.
ACI Universal Windshield Wiper Systems Quality Washer Pump Kit reservoir 99300 This is also on Amazon.
76 LUV
