It is currently Mon May 25, 2026 6:23 pm
PostPosted: Sat Jul 18, 2020 5:53 pm
With the stock harness having small gage wire and being so old, The only viable option that i can see is to use the original ignition power wire to trigger a relay to power the H.E.I. This way, I can Run 12 ga. wire. I've used the original power wire to handle H.E.I. since 1986 with my first Buick V-6 conversion. I'm Thinking that the stock 20 ga. wire has degraded enough that it's affecting my ignition system. If anyone has a good plan to run wiring, I'd like to hear them. Thanks!
