It is currently Fri Apr 19, 2024 4:55 pm
 Post subject: $$$$ for information
PostPosted: Tue Apr 17, 2018 12:07 pm
Got your attention!!! When 85 trooper P/S box is installed in a 80 Luv truck, Do you use the trooper pitman arm or the luv truck pitman arm? How much do I owe you?
 Post subject: Re: $$$$ for information
PostPosted: Fri Apr 20, 2018 3:05 pm
The answer to my question is neither one. The luv pitman arm will not work on the trooper power steering box, I tried it and does not match up. I have to assume that most of the installations of power steering is mostly to 4x4 luvs with different steering components installed like drag link and steering arm. I'd sure like to talk to one who has installed power steering into a 2 wheel drive, stock steering components Chevy Luv truck.
