It is currently Fri Jul 18, 2025 5:33 pm
 Post subject: Front Spindles
PostPosted: Wed Nov 01, 2017 5:55 pm
We just picked up a '75 to work into a track truck. It has drum brakes all around and I would like to change the fronts to rotors, but I am a little lost on the first step I need to take. There are plenty of threads on swapping for trooper calipers and rotors, but I know I need a few parts first.
I believe the spindles are the same for drums and rotors, but I would need to get the caliper bracket from a luv with discs (or a whole spindle assembly) correct? My searches for just a mounting bracket have been unsuccessful. Is there anywhere else to get a mounting bracket? I have lead on a 4x4 Luv parts truck in my area, is any of that usable in my situation? I'm not worried about bolt pattern or anything just want to stop a little better.
Thanks for the help!!
 Post subject: Re: Front Spindles
PostPosted: Wed Nov 01, 2017 7:03 pm
Spindles are the same. In the info section Ben did a write up. PM Wildluvracin, he has a couple trucks he is parting out.
PostPosted: Wed Nov 01, 2017 8:38 pm
Sent you a PM huskar
