It is currently Mon May 25, 2026 3:36 am
PostPosted: Sat Nov 15, 2014 2:27 am
how do you use a jump wire to test the relay to see if fuel pump works ? what #s on the relay terminals do I connect to ?? someone have pics or info...?...
PostPosted: Sun Nov 16, 2014 12:39 pm
The black with red tracer is the wire going to the fuel pump. Not sure of the terminals but get a test light, find key on power and jump it to the BR wire, you should hear the pump run.
