It is currently Mon May 25, 2026 3:38 am
 Post subject: Centering rear axle
PostPosted: Tue Aug 26, 2014 7:27 pm
So i have a 1980 luv and the leaf springs,shocks have been taken off. Im going to bag it but how can i make sure the rear end is perfectly centered between the frame before cutting out notch for frame and welding links in place?
 Post subject: Re: Centering rear axle
PostPosted: Wed Aug 27, 2014 10:49 am
Level the frame. Then drop a plumb Bob from each shock mount. Use those two points to center the axle laterally and fore -aft .
