It is currently Mon May 25, 2026 2:42 am
PostPosted: Fri Mar 21, 2014 9:03 pm
Hello all,
I tried the search pages and couldn't come up with anything. I have a 79 4WD that I am converting to 2WD. Will 2WD hubs fit on the 4WD spindle? The 4WD hub uses a whole different type of bearing set up and preload, Right or wrong. I will also be converting to 5 lug with the S-10 bolt pattern. Thanks
PostPosted: Fri Mar 21, 2014 10:42 pm
I have the same question. I know it was off handedly mentioned to me that you can swap the spindles with their hubs but not just hubs. i havent verified yet.
PostPosted: Sat Mar 22, 2014 9:35 pm
Yes, hopefully someone will chime in. I am in the process of putting a 4.3 into mine also.
PostPosted: Thu Mar 27, 2014 1:02 am
seems to be becoming a common swap. easier than sbc and most of the same benefits
ask oldestisuzuist he should know
