It is currently Mon May 25, 2026 2:42 am
 Post subject: Bench seat cover?
PostPosted: Fri Dec 20, 2013 8:53 am
Does anyone know if this seat cover will fit my 80 stock bench seat?
http://www.ezsofttops.com/p-2657-1982-9 ... vinyl.aspx
I'd like to get it in black. I'm redoing all of my interior.
it be like that sometimes
 Post subject: Re: Bench seat cover?
PostPosted: Fri Dec 20, 2013 9:59 am
No , but it would be cool if it did fit nice . Seat recovered for less than $200 sign me up .
PostPosted: Fri Dec 20, 2013 10:57 am
I found the s10 bench seat specs, and then measured mine. They were almost exact.
PostPosted: Fri Dec 20, 2013 6:07 pm
You may be in luck then, only one way to findout really and it involves risking your money :lol:
As long as its not too small you can make it work by going behind and below to pull the material so it fits snug and sew it that way out of sight. Pretty much what an upholsterer would do
PostPosted: Sat Dec 21, 2013 4:10 am
Is an 80 bench seat the same as a 74? I am interested in trying this!
PostPosted: Sun Dec 22, 2013 2:15 pm
I think it is, actually
PostPosted: Thu Dec 26, 2013 6:01 pm
Well I ordered one.
Fingers crossed it doesn't turn out as an expensive blunder!
PostPosted: Fri Dec 27, 2013 12:50 am
Anthiron wrote:
Well I ordered one.
Let me know!
PostPosted: Fri Dec 27, 2013 1:53 am
if it fits it will be another option for us with bench seats! would look better than my daggy seat cover!
1976 Luv
1980 Isuzu kb 4x4
Nissan GU Patrol
Ford Falcon AU ute
PostPosted: Sat Jan 04, 2014 5:11 pm
any updates?
PostPosted: Sat Jan 04, 2014 5:55 pm
I'm in Australia.
It hasn't arrived yet unfortunately.
PostPosted: Mon Jan 13, 2014 10:45 pm
Anthiron wrote:
I'm in Australia.
Any word?
PostPosted: Wed Jan 22, 2014 7:55 pm
I got the upholstery kit the other day and fitted it yesterday.
The backrest section was perfect. I just removed the Zipper and used C clips and C clip pliers to attach it.
The lower section was a bit more tricky and didnt come out perfect.
The S10 must have a straight edged lower seat piece. Where as the Luv lower section curves in towards the back rest. also I had to unpick some stitching to get the rear flap to strech over the pivot bar and underneath to clip on. The driver side didnt stretch as well as the passenger side so I am hoping that I can fix this on a hot day.
I also had to cut the holes for the back rest pivots.
The lower section also has flaps for the seat belts and these are not neccesary for the Luv but they arent punched through so they just look a bit wierd.
It seems as though they make the kits when you order them so it might be possible to ask for alterations.
Nick
PostPosted: Thu Jan 23, 2014 12:33 am
That came out lookin pretty good!
PostPosted: Thu Jan 23, 2014 12:54 pm
Man, that does look really good.
Would you say it's worth it?
PostPosted: Fri Jan 24, 2014 4:39 am
I'd say yes.
Just be prepared to have the be a little creative.
PostPosted: Fri Jan 24, 2014 9:19 am
Well that's good to hear. Thanks for letting me know!
