It is currently Mon May 25, 2026 7:27 am
 Post subject: 4x4 luv to 2wd
PostPosted: Fri Nov 16, 2012 3:28 pm
Hey everyone i have wanted a luv for 21 years now i finally bought an 80 mikado 4x4 i was wondering what i would need to convert this truck to a 2 wheel drive. Has anyone done this? Any details would be greatly apreshiated
im doing a v8 swap so im just talking about front end parts
also if anyone needs a factory 1.8 and 4 speed setup with 3,900 miles on it let me know i am in canton ma.
thanks
There can always be more then 1 LUV in your life
 Post subject: Re: 4x4 luv to 2wd
PostPosted: Fri Nov 16, 2012 7:47 pm
Just my two cents worth but I would keep looking for a two wheel drive LUV.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Mon Nov 19, 2012 8:41 pm
Hello
How much do you want for the 1.8 Motor?
Thanks
PostPosted: Sun Nov 25, 2012 2:01 pm
were i live it took me 15 years to find this 1 so waiting on a 2 wheel drive might take me till im old and grey but if someone is in ma. and wants to trade a 2 wheel frame for a 4wheel frame Ill include everything for you to be 4 wheel drive
PostPosted: Thu Nov 29, 2012 6:33 pm
Not sure if you might be interested or not, but I have a 2wd long bed that I would like to find a good home for. If interested make me an offer.
http://scranton.craigslist.org/cto/3394155166.html
http://www.purerockradio.net/
PostPosted: Thu Nov 29, 2012 9:26 pm
Heck I'd be tempted to trade you strait out for my 2wd luv. :D
PostPosted: Tue Dec 04, 2012 9:35 pm
It's a shame to lose the 4wd but if you're determined to do it, I think you just unbolt all the front drive stuff. The suspension still works without an axle in it.
It might even be an advantage over the 2wd chassis. I saw one many years ago and, at the time, I thought the 'swept back' lower control arms from the 4wd chassis gave a little more room for the V8.
You went there in that?!?!
PostPosted: Tue Dec 04, 2012 10:09 pm
If you look up chevy luv on craigslist there is a luv for parts in Denver Colorado. It should have all the parts you need.
PostPosted: Sat Dec 07, 2013 2:17 pm
4x4 to 2x4 soaking the splines on the torsion bar ajusters to get the height way down and still have some spring to it,
PostPosted: Sat Dec 07, 2013 10:18 pm
I pulled all the 4x4 components off my luv to go 2wd with a 4.3. Around page 15
viewtopic.php?f=33&t=22916&start=300
Its fairly straight forward but dropping the axle out is a headache
Make sure to seal off the back side of the hub to keep water and dirt out
