It is currently Mon May 25, 2026 2:40 am
 Post subject: luv bolt on ifs swap
PostPosted: Tue Apr 23, 2013 12:13 am
im new here,does anyone know if anyone makes a direct bolt on ifs clip for chevy luvs?im told the mustang II would work,and i like the room plus the rack&pinon,i hate the idea of cutting my frame rails.thanx mines a 75 luv
 Post subject: Re: luv bolt on ifs swap
PostPosted: Tue Apr 23, 2013 8:12 am
19 views and no reply?
No one wants to be the bearer of bad news?
PostPosted: Tue Apr 23, 2013 1:28 pm
You mean that the words "bolt on" and "luv" dont go in the same sentence?
PostPosted: Thu Apr 25, 2013 12:21 am
Like Tilted hinted at, there is very little that is bolt on for our trucks. If you want to go IFS you are gonna have to do a bit of hacking and fab work. If you do a lil bit of searching there are a few posts of doing the rack and pinion and coilover conversions on this site.
PostPosted: Fri Apr 26, 2013 9:22 pm
IFS = Independent Front Suspension all luvs are independent front suspension? ? or what exactly do u want???? or did you mean IRS? independent rear suspension?
PostPosted: Tue Sep 10, 2013 3:31 pm
Anyone know what the front of these trucks messure? I'm looking to have a guy make a IFS mustang II front end kit for my 76 LUV but my frame has been changed I think!! Can anyone help I need inside to inside of front frame messurement and does anyone know front hub to hub?
http://youtu.be/wj7EmhyQrbY
PostPosted: Tue Sep 10, 2013 5:46 pm
There is a member here who had one done.
viewtopic.php?f=33&t=26874&start=0
I don't know if its hub to hub but here is track width info.
http://www.luvtruck.com/PDF/LUV_Demension.pdf
PostPosted: Tue Sep 10, 2013 6:40 pm
This appears to be another hit-and-run. The guy has not even visited the site since April 28. Replies are probably wasted.
PostPosted: Tue Sep 10, 2013 7:24 pm
I posted for ourtwisted, he is looking and will be back.
PostPosted: Wed Sep 11, 2013 4:43 pm
THANK YOU luvrV8 ... :P
PostPosted: Wed Sep 11, 2013 7:13 pm
WMS to WMS on the rear axle is 54", the dimensions noted in the link are the centerline of the tire/wheel, which changes with the wheel width, offset & backspace. Since the front is noted as wider to the same place I would expect it to be 55-1/4" WMS to WMS. It's common for the front to be wider than the back to space the tires away from the frame at full turn.
PostPosted: Wed Sep 11, 2013 9:17 pm
Ourtwisted, this shop is 5 miles from my house (Scott's hotrods) if I Alan help in any way from here let me know. I can say his shop has a great reputation out here.
PostPosted: Thu Sep 12, 2013 4:42 pm
Thanks ill have to look them up!!
thanks for the info oldestisuzuist cause mine was 56" which I thought was weird but seems to have worked out some how.. lol
PostPosted: Fri Sep 13, 2013 2:04 pm
Hey guys. I passed the info to him awhile back. He is local to me. Thanks Luvr8 for offering up to visit Scott's. They did a great job for me. It looks good, but can't say how it rides, yet. The next step is engine and trans, then on to stripping and painting.
Batch
PostPosted: Wed Sep 18, 2013 3:52 pm
Hey any of you guys or gals have facebook look me up! I just ordered a Jonny Law mustang II setup and will be updating my page with the build!! https://www.facebook.com/luvtruck
PostPosted: Wed Sep 18, 2013 6:04 pm
ourtwisted3, I think you are close to me. You can come by and take a look at mine if you like.
Batch
PostPosted: Mon Jan 13, 2014 4:46 am
Forgive my ignorance, but what does WMS refer to? Does that mean "wheel mounting surface" (ie hub face to hub face)?
When the only tool you have is a hammer, everything looks like a nail.
PostPosted: Mon Jan 13, 2014 9:34 am
Correct, WMS=wheel mounting surface
"Track" generally refers to the distance between the centerlines of the tire/wheel combination & is the same as WMS distance only with zero offset wheels.
