It is currently Tue Apr 23, 2024 1:55 pm
 Post subject: center cap help
PostPosted: Mon Apr 15, 2013 10:25 pm
I have a set of nissan pathfinder wheels and center caps for them. The rear fit fine but up front i have about a 1/4 in gap between center cap and rim because of the dust cap. I did a search and found that people are either taking off the dust cap or using a wheel spacer. I was wondering if any one had any other suggestions, if not what kind/brand of spacer would you all recomend?
[img][IMG]http://i632.photobucket.com/albums/uu46/chevyluv76_me/rim.jpg[/img][/img]
[img][IMG]http://i632.photobucket.com/albums/uu46/chevyluv76_me/centercap.jpg[/img][/img]
 Post subject: Re: center cap help
PostPosted: Mon Apr 15, 2013 10:32 pm
Get a thinner castelated nut from the local bolt supply, install it. Drill the spindle for a new cotter pin hole, then cut the excess off. Then you can either cut/weld the dust cap, or flatten it slightly...
