It is currently Mon May 25, 2026 2:40 am
 Post subject: torsion bars problems
PostPosted: Mon Mar 25, 2013 4:51 pm
I just put in 3 in lowerimg blocks in the rear end of my truck, i also tried loosening torsion bars on the front of the truck and the front wont drop.... what am i doing wrong??
PostPosted: Mon Mar 25, 2013 8:37 pm
make sure that you are not on the bump stops in the front /they are little rubber bumpers on the frame that hit the a arm when you lower them alot
PostPosted: Tue Mar 26, 2013 1:07 pm
According to the factory service manual you should also loosen the bars that connect the front suspension to the frame at the front of the truck. Don't take them off, just back off the bolts a bit. Then once you have the level you are looking for they should be retorqued to spec. (Which I don't remember, but its in the Haynes service manuals)
I should also stress you should support the frame of the truck while you are adjusting the torsion bars, I broke the adjuster bolt on my 4x4 when I was working on it. A block of wood I had under the frame "just in case" caught the truck on its way to the floor.
Sounds most likely that you are already dropped in the front and it has hit the bump stops. You can get low profile bump stops made from poly to replace the stock one. 4x4 shops would be a good place to look for them, like www.independent4x.com
PostPosted: Thu Apr 11, 2013 10:20 pm
either bump stops of your shocks can be bottoming out and limiting you .
