It is currently Mon May 25, 2026 11:29 am
PostPosted: Sat Jan 19, 2013 4:51 pm
My buddy and i got together made a jig and this is how it came out..
PostPosted: Sat Jan 19, 2013 4:56 pm
im interested to see how that turns out 8)
PostPosted: Sat Jan 19, 2013 7:05 pm
Nelson! Those look like mine...
PostPosted: Sun Jan 20, 2013 1:28 am
Yep i had to make these since u didnt wanna sell me urs :(..
Well its late and finished installing them..
PostPosted: Sun Jan 20, 2013 6:20 am
Thats it . Did you have an index appendage to go 72 degrees ? How did you create the jig ? I am doughting you did this with a drill press , what type of machine did you use ?
I have a set of redrills and they look exactly like this .
PostPosted: Sun Jan 20, 2013 10:51 am
I usef one of those fancy drill press where u can level the table..
PostPosted: Mon Jan 21, 2013 12:29 am
How many of u guys would be interested in getting ur rotors drill? Im thinking about making a better jig since after i drilled my rotors i had to tap it so it can be made into my tap guide jig? So i would have to make a drill only jig with hardened drill bushings so it can last sevral redrils..
PostPosted: Mon Jan 21, 2013 7:59 am
Im sure there would be a few on here interested . It seems to come up often .
PostPosted: Mon Jan 21, 2013 11:56 am
I would be interested
PostPosted: Mon Jan 21, 2013 10:34 pm
Looks like i would need to do about 4 pairs of rotors at $60 a rotor to cover the cost of the new jig with taps and drill bits and moser studs and some money to use my buddies fancy bridge port
PostPosted: Fri Feb 08, 2013 8:59 pm
Just finished perfecting the jig :ebiggrin
