It is currently Mon May 25, 2026 8:14 am
PostPosted: Tue Dec 04, 2012 10:04 pm
I have a 72 luv with a 273 comando engine, I am puting in an aerospace front disc brake kit now I want to change it to power steering, I can't find a kit on how to change the manual steering to power steering any suggestions?
PostPosted: Wed Dec 05, 2012 3:22 am
viewtopic.php?f=7&t=2325F
PostPosted: Wed Dec 05, 2012 12:21 pm
Off topic slightly, but how about a pic of the installed Plymouth...
PostPosted: Wed Dec 05, 2012 9:49 pm
I will be putting pictures on in the next week or so. Thanks for the reply. This blog is neat I luv seeing what others have done with these trucks!!
PostPosted: Thu Dec 06, 2012 5:38 am
This is a must see . I always wanted on with a AMC motor
PostPosted: Sat Dec 08, 2012 11:19 am
If power steering isn't an option I would consider rack and pinion. Has anyone else found a better option than the hard to steer manual steering box?
PostPosted: Sat Dec 08, 2012 11:33 am
You can get the hoses adapted over from the pump you can find to fit your set up to the steering box in the link. I adapated the saginaw power steering box on 350 Vortec chevy to the power steering box on a Nissan Hardbody truck I am currently working on that way. And tj white is a member on here who converted his LUV to a rack set up to clear a 455 buick, and has some pretty decent pics on here somewhere...
PostPosted: Mon Jan 21, 2013 9:42 pm
No longer have the Aerospace Brakes for this truck, Looking for a 78 or newer LUV front disk brake assembly, Anyone know where to buy it?
