It is currently Mon May 25, 2026 10:22 am
 Post subject: 1980 luv 4x4 lift
PostPosted: Thu Sep 06, 2012 9:50 pm
ok i have found 5 inch blocks for the back but how do i luft the front aside from cranking the t bars is there another way to do it ? i dotnt want to throw it out of alignment by cranking t bars im wanting to get 3-5 inchs of lift on it i can get 3 4 and 5 inch bloccks but i need to figure out what to do with the front before wasting my money on the wrong size blocks for the back
if it aint a luv it aint shit
 Post subject: Re: 1980 luv 4x4 lift
PostPosted: Fri Sep 07, 2012 8:05 am
Blocks will only lower it. The axle is on top of the leaf springs on these trucks. You need shackles to lift the rear.
PostPosted: Fri Sep 07, 2012 1:32 pm
indeed i forgot about the axle being on top of the leafs but what shackles do i and what about the front can i do it with out cranking on the t bars ?
PostPosted: Fri Sep 07, 2012 3:21 pm
Shackles or SOA in the rear.
I have heard of people indexing the torsion bars to get more lift in the front.
PostPosted: Mon Oct 22, 2012 3:38 pm
I just went through the process of adding about a 2 1/2" lift on my 1980 Luv Machine. I turned the torsion bars clockwise about 6 turns and shackled the rear. After a little research, I ended up buying Mr. Gasket universal shackles for about $35. The only problem with those were the holes. At 7/16", they werent even close. So I had to buy a 3/4" drill bit, 4-3/4"x4" grade 8 bolts with nuts and washers. Total time i had invested in the actual work was probably three hours including fender and shackle trimming for the 215 tires.
