PostPosted: Sun Jul 01, 2012 1:20 am
anyone tried a cage kit from these guys? they have 72-80 LUV listed on the site
i dont need one any time soon but someone might :lol:
http://autoweldchassis.com/rbc.ivnu
PostPosted: Tue Jul 03, 2012 6:49 am
LSX LUV Owner
There are several company's the make pre bent cages for LUV's. I know hotrod80 had a pre bent cage in his blue luv, and it looked like it fit pretty good. I think the DOM cages for for nearly twice the price of EWS cages.
PostPosted: Thu Jul 26, 2012 4:52 am
My Blue truck had S&W mild steel 8 point . My current truck is 12 point Chromemoly that was custom built . The S&W fit pretty nice and was somewhat adjustable . My Yellow truck the 12 point is almost invisible . Chassis shops can be hit and miss . Not everybody does work like wicked .
PostPosted: Fri Jul 27, 2012 5:33 pm
one of these days i will have the power to need one but that will be a while :p
the only thing that bugs me about a lot of cages is having them exit thru the rear window instead of the top of the cab above the window. i know i saw one that came out above on someones luv that looked good.
no kidding tho wicked has some great looking tube work on his luv; if he was closer i would see about having a 3 link and new front end done :lol:
PostPosted: Fri Jul 27, 2012 10:21 pm
Mine is above the window and through the cab. Not good for a daily driver though unless you get a canvas boot that will zip around it you can attach to the cab to keep the water out...
PostPosted: Tue Jul 31, 2012 7:29 am
especially being here in the rainy state of washington... would need to get it sealed up really well or it would be rusting the cab within a month...
what about running the rear support bars lower down right under the window with a slight up curve once inside to be a bit less conspicuous? wouldnt be quite as strong but im not hitting the drag strip often :lol:
PostPosted: Fri Aug 03, 2012 12:33 pm
Bickel race cars makes some very cool billet boots that slide on the pipe before welding them and have a ring with 4 screws on the body part . Super nice
