I lowered the torsion bars all the way, used 4" blocks in back, then took the "overload" type spring (the flat one on bottom) and put that at the very top of the spring pack, which kinda flattened the whole pack out. I also left off the second to bottom one out. By removing the bottom two and putting the bottom one on top, I estimate 6" or more of drop in back. The main reason I removed the bottom two, was to get some more ground clearance on my shock mounts. With the torsion bars all the way down, bump stops removed obviously, the truck sat pretty level, without any rake or squatting. It rode like ass, but thats what you can expect from a truck with torsion bars all the way up or down. The top of the tires (175/70R14) were tucking under the edge of the fenders in front and back. With some 15" low profiles, it would be much lower to the ground, without as much tuck. I was going to run some 17's which would tuck great and give me a little more ground clearance on the frame. Looked pretty good though, sorry no pics, and I don't have the truck anymore
