It is currently Mon May 25, 2026 11:26 am
 Post subject: Best Custom Coils
PostPosted: Fri May 11, 2012 1:53 pm
custom coils. its so ridiculously easy and really smooths out that rough ride. Rockauto.com sells the Monroe Sensa-Trac shocks in a pair $60 bucks. S-10 shocks are pretty much the same except for the brakets on the bottom of the shock. (or bel-air shocks work as well 53-56) So being creative id thought id give a lil conversion a try.
-So i purchased a pair of 1983 S-10 Monroe Sensa-trac shocks front.
-When they got here i purchased a skill angle grinder with the metal cutting disc.
-Two metal sleves that match the old shock hole but one size up.
-Get Another bolt size up thats flush with the new sleve (automotive grade)lock washers.
-everything one size up with the bolts and hole size. important info.
**GET STARTED!!!**
-I cut the brakets off as flush as i could with the grinder.
NOTE:::(make sure you have a big drill bit but not bigger than the sleeve (dont mess it up) just get a bit one size down.so that sleeve fits tight.
**NOW!!!!**
-A heavy duty drill is needed to perforn the rest of the task, and thats drilling out a straight hole for the sleves.
-after the hole is drilled use and kind of grese or lube to get that sleeve in the bushing hole, i used liquid wrench and a rubber mallet so i didint bend anything.
- let it dry
-then drill out the hole on trucks shock mount to match the new bolts should use the same bit for everything.
- And whala son u got urself a pair of cheap custom coils.
Willing to convert some for others jus for the fun of it and to make a lil buck. let me kno. DEREK M.
 Post subject: Re: Best Custom Coils
PostPosted: Fri May 11, 2012 2:50 pm
Pics!
PostPosted: Sat May 12, 2012 5:43 pm
will do will post them by monday
PostPosted: Sat May 12, 2012 5:51 pm
Like this?
PostPosted: Mon May 14, 2012 10:36 pm
What are you using for font brakes
PostPosted: Tue May 15, 2012 4:01 pm
yea similar to that mytmouse. what kind of setup do u have. and wat kinna shocks are those. did you cut ur aswell? gonna post pics this week!!!!!!!!!!sorry been real busy.and whats this guy talking about front brakes????lol
PostPosted: Tue May 15, 2012 4:19 pm
The shocks are Monroe with a helper spring. He might be referring to my willwood set up in the pic...
