idk if this is something you would be intrested in but
When we did the interior of my cousins 69 camero we bought like 12-15 yards of heat moldable carpet ... it was something like $3-$8 a yard... and to answer the next questions no i dont have pictures of it in the car or a link to any products....
but a quick google search for heat moldable carpet might get you where you need to be...
any ways how we did it was measures the interior (longest and widest points) with a piece of string from one side to the other alowing the string to follow the conture of the paneling... then added 8" at the widest/longest - deepest place and cut to that mesurement started at the front with heat and worked diagonally across then started again... did this about 3-4 times till the carpet was relaxed in position then cut to trim length and installed the rest of the interior... did the same thing with the trunk
_________________ Friends don't let friends drive stock... 76 mikado, emissions delete, dual alternator, rejetted 1.9 carb swap, non factory body lines soon non points distributor, single (semi sealed beam) head light conversion
