It is currently Tue May 26, 2026 12:04 am
 Post subject: Lift
PostPosted: Fri Dec 09, 2011 10:54 pm
Want to put a lift, anything I should know?
 Post subject: Re: Lift
PostPosted: Sat Dec 17, 2011 6:34 pm
righty-tighty, lefty-loosey
PostPosted: Sat Dec 17, 2011 7:48 pm
How you gona lift it? Your pretty limited. What are you gona do? body lift? or T-bar crank? or trooper control arms? these are pretty much it for bolt on.
PostPosted: Wed Jan 04, 2012 2:12 pm
lifting the rear is fairly easy drop shackles, add a leaf, longer springs... 2" body lift, front is the hard part... cranking the tortion bars or drop spindals
