It is currently Mon May 25, 2026 9:19 pm
 Post subject: 4link Rear End
PostPosted: Mon Aug 15, 2011 1:40 am
Has anyone done a 4link set up on the rear end?? I see slot of universal kits out, anyone recommend a specific one~
 Post subject: Re: 4link Rear End
PostPosted: Fri Aug 19, 2011 9:05 am
whats the truck gona be used for would help a lot..theirs a lot of diff styles of link setups out their but some work better with diff suspension set ups..
Epic Fabrication.
KAOS
PostPosted: Fri Aug 19, 2011 7:29 pm
Pretty much a light duty setup to replace the leaf springs.., nothing fancy..., also would rather use coil-over's rather than bags...
PostPosted: Fri Aug 19, 2011 9:29 pm
there have been a $h!tload of 4 link setups done on luvs for bags and for coils. im considering a 4 link with coils for mine after i do the turbo swap
PostPosted: Fri Aug 19, 2011 11:44 pm
Any particular brand or maker that is easiest for swap? I have access to a welder so that shouldn't be an issue, I would like to be able to do it with out notching the frame and/or bed.
PostPosted: Sat Aug 20, 2011 11:01 am
im partial to suicide doors or well now" quality air ride" for the craftmanship or well cause their bag as hell and id trust em for bout anything....but as far as a style to go would be the hardest tot answer cause to the simpe fact of every one places stuff in different locations..but if you jus looking to link it up and run the coil on axle or off the back of it, for simplicity id do a 2 link with a wish bone top link...and use the front leaf hanger for the lower link bars front mounts ect..ect...pm me if ya want more info.hope this helps
Epic Fabrication.
KAOS
PostPosted: Sat Aug 20, 2011 10:28 pm
With a wish bone you would have to relocate the ga tank correct? Not saying I wouldn't..., but les mod on other items would be ideal. I know, I'm sounding picky...,
PostPosted: Sun Aug 21, 2011 7:18 pm
no jus off set the wishbones front bushing n youll beable to keep it in stock location and have the left side of the link bar bent to clear..
Epic Fabrication.
KAOS
PostPosted: Mon Aug 29, 2011 12:32 pm
Qualityairride.com(suicidedoors.com) 4-links are expensive, lol
I built my new wish bone 4-link and cost $150 cheaper than QAR
