It is currently Fri Jun 26, 2026 10:18 pm
PostPosted: Sun Aug 14, 2011 3:28 pm
Thanks to 72 luv thing for being the first and sharing
The seal used is for a 68-79 VW bus side window without vent wing.
I got mine at Bill & Steves VW parts in Downey CA part number 221845321A
They are readily available at VW restoration shops for $30
I would say it is a good alternative for a cracked or damaged seal but it is not an exact replacement. I took a slider window when I bought it and it was snug on it. I have a flex thru on my truck which seems to be smaller than my slider is. The seal was loose on the flex thru. It was a little weird putting on and the flex thru seems to barely fit in the seal, but it is much better that the stock damaged seal I had. I am almost thinking my flex thru is for a Datsun not a Luv. That being said I think a slider or a stock window would fit the seal better.
Here are the seals side by side
This is a potential drawback, depending on your paint job the new seal may not cover the same area.
I used some SEM trim black to disguise the ugly
PostPosted: Sun Aug 14, 2011 3:31 pm
The final result a nice fresh seal.
PostPosted: Sun Aug 14, 2011 3:32 pm
PostPosted: Sun Aug 14, 2011 3:33 pm
And needs to be a sticky somewhere IMO...
PostPosted: Sun Aug 14, 2011 9:55 pm
i vote sticky
1980 Chevy LUV 4x4 Weberfied Sold
1974 Chevy LUV 4x4 Weberfied
PostPosted: Tue Aug 30, 2011 12:47 am
Vote Sticky, Bump~
PostPosted: Tue Aug 30, 2011 11:53 am
http://www.vwparts.net/221845321.html
PostPosted: Tue Aug 30, 2011 12:28 pm
HomeGrown76Luv wrote:
It needs to be a 68-79 Bus side window (no vent wing), this looks like a 67 which would be too small.
PostPosted: Tue Aug 30, 2011 1:20 pm
The part numbers are the same~ minus the "A"...,
PostPosted: Tue Aug 30, 2011 1:51 pm
Here is where I got mine at
Bill & Steve's
12121 Lakewood Boulevard, Downey, CA
(562) 923-3251·
http://www.billandsteves.com
PostPosted: Tue Aug 30, 2011 5:59 pm
would this seal work for the real thick slider back glass? you know the ones that is like an inch thick?
PostPosted: Tue Aug 30, 2011 9:51 pm
Yes it will work, I took my extra slider to the VW shop and tried it on there.
PostPosted: Wed Aug 31, 2011 4:52 pm
ok thanks and i found some factory dashpads on ebay for 50 bucks then some for 70
PostPosted: Thu Sep 01, 2011 8:17 am
Those are just hard plastic dash caps. They are a good alternative to a new dash though.
PostPosted: Thu Sep 01, 2011 8:32 pm
oh well i just seen them and looked at my bare metal dash and thought, shew wouldnt that look better hahaha
PostPosted: Thu Oct 06, 2011 4:51 pm
Im glad my it worked for you as well , VW to the rescue !!
PostPosted: Thu Oct 06, 2011 6:49 pm
PostPosted: Sat Mar 31, 2012 1:01 am
were can you find these flex-thru windows having trouble
PostPosted: Sat Mar 31, 2012 9:43 am
They have not been made is decades, good luck.
PostPosted: Sat Mar 31, 2012 2:16 pm
It only took me 20 years to find mine.
