It is currently Mon May 25, 2026 6:49 pm
PostPosted: Tue Apr 12, 2011 7:33 am
Is there an easy way to either remove or get access to clean the screens under the cowl in front of the windshield? I have some pine needles and stuff in mine I'd like to remove before they cause rust. My truck is a stock 1980 4x4 Luv
PostPosted: Tue Apr 12, 2011 10:37 am
you well have to remove the windshield wipers and then open the hood and look allong the fire wall edge of the cowl plate to find the screws that hold the plate on and when removed pull up alittel then pullout towards the front and your out . then youll see what to do . ps dont run a lot of water down the holes cuz two of those hole lead to the inside of the truck good luck
PostPosted: Tue Apr 12, 2011 3:19 pm
couldnt have explained it any better
PostPosted: Thu Apr 21, 2011 11:38 pm
Then add window screen below the cowl so you don't have to clean it again and again.
