 Post subject: Wheel adapters
PostPosted: Wed Feb 09, 2011 2:41 pm
OK Guys, need input on this I found billet aluminum 6 X 5.5 to 5 X 4 3/4 they are 2 parts add 2" to the hub. they suggest that if your stock studs are too long to cut them then there are screws to attach the second part they say to use lock tight as well they also stated that wheel adapters are a pain in the back side as well. I ran adapters on a baja (VW) but they were steel and and used stock nuts.
Just your input would be great I've done a many searches as well as a few PM's on my prep for a build I need your wisdom on this one I won't be doing wheel stands. just an alternative possibility. They want $220 for 4 plus $20 in shipping.
Enjoy, The mouse trap is comming!
