It is currently Mon May 25, 2026 5:09 pm
PostPosted: Wed Nov 17, 2010 2:27 am
what do you guys think about running my stock rearend with the 4 56 gears behind a turbo 350 trans and a chevy 350 small block..stock with cam and intake..has anyone had this on the track and hold up?...running radial tires only no slicks...
PostPosted: Wed Nov 17, 2010 10:01 am
It will last as long as it doesn't hook...
PostPosted: Sun Nov 21, 2010 7:43 pm
it will to a point . The driverside axles always seem to break first as they are being forced into the ground . Seen a guy go 10.80's on a stock one .
PostPosted: Mon Nov 22, 2010 12:41 pm
I think you would be fine Len. LUVSADRAG on here ran a stock welded one under his truck years ago, slicks and all. Seen a primered LUV go 10.50's on the stock rear a couple years back and it didn't break (yet!) so you should be good to go.
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
PostPosted: Sun Nov 28, 2010 9:48 pm
Welded the spider gears on mine and ran a 10.5 inch slick.Truck ran 7.0 in the 1/8th before the u-joints started breaking, but the rearend did just fine.
PostPosted: Tue Dec 07, 2010 9:49 am
We've been 10.30's with the stock one. 1.45 60ft
