It is currently Tue May 26, 2026 1:38 am
 Post subject: s10 frame swap anyone?
PostPosted: Tue Aug 24, 2010 7:49 pm
has anyone ever swapped out there entire frame from the luv to an s10 i have a frame i could possibly use what major mods if any would need to be done lemme know thanks
PostPosted: Tue Aug 24, 2010 8:06 pm
Stock LUV frame is WAY stronger, if it is just the 6 lug thing, IMO, it would be better to do one of the 5 lug swaps that are floating around...
PostPosted: Tue Aug 24, 2010 8:08 pm
i have a completely boxed frame front engine x member is notched and plated its got a narrowed rear clip fuel cell mounts and battery mount all work is done to it to be a full race frame and i was considering swapping my luv body onto it plus get the benefit of the nicer front suspension with a zq8 steering box
PostPosted: Tue Aug 24, 2010 8:12 pm
OK, that is a little different. I haven't swapped between them, but the track width is narrower on the LUV front and rear, so mods would be needed to get the front wheels tucked in...
PostPosted: Wed Aug 25, 2010 8:25 pm
are u sure about that? i have an s10 rear in my truck as many people do with no issues
PostPosted: Wed Aug 25, 2010 8:37 pm
You have an s10 rear, but you have offset wheels. You will have to do the same with the front. Not sure if it will work then, as even a skinny front racing wheel sticks out on a LUV front. I have a s10 and a LUV in the garage, the difference is noticeable to me...
PostPosted: Mon Aug 30, 2010 9:56 am
I would still think the Stock luv frame is much stronger than the S10.... even fulley boxed.
You have to remember that in japan, these trucks were required to fill a 3/4 tons trucks job.
A.j.
PostPosted: Wed Nov 10, 2010 8:12 pm
My pop and I did back in 92.. My Daughter just recieved that Luv for her first hotrod prodject. Lotta mount fabbing, but can be done
PostPosted: Mon Nov 22, 2010 7:45 pm
Newbee here, I have a 1975 Chevy Luv shell, was thinking of puting it on a later model 4X4 S-10 with a six cyl. Have you received any new info regarding your post?
