It is currently Mon May 25, 2026 12:39 pm
 Post subject: s-10 to luv mating
PostPosted: Tue Nov 16, 2010 6:04 pm
Ok i stated in a previous post that i picked up a 81 chevy luv pickup, well mostly im missing or have dented sheet metal. I found a s-10 82 model i believe that I was wondering if the cab and front clip would fit on the luv. my luv being 4wd and the s-10 not i figured that would be the easiest way instead of transplanting everything into the s-10 and having to worry bout mounting everything and installing the 4wd. I guess what im asking is would it be easier to put the s-10 cab on the luv frame and not worry bout engine trans and 4wd swap or should i put all my luv parts in the s-10. thoughts, opinions, sugestions, offers, trades im open.
 Post subject: Re: s-10 to luv mating
PostPosted: Mon Nov 22, 2010 7:40 pm
I'm a newbee, have 1975 Chev Luv, shell is good, would like to make alot of upgrades, thought maybe it would be easiest to put my Luv shell on a later model 4X4 S-10 frame, 6 cylinder. I am not a mechanic or what you would call a car guy. Any information would be appreciated.
