It is currently Mon May 25, 2026 8:18 am
 Post subject: driveshaft
PostPosted: Mon Aug 16, 2010 6:55 am
my luv is up and running but missing the driveshaft, anyone know what other driveshaft will fit in the tranny the rear has to be changed im running an s10 axle but having the front sure would help right now any help would be great thanks
 Post subject: Re: driveshaft
PostPosted: Fri Aug 20, 2010 7:32 pm
send ctmandu a pm... he might be able to tell you... he is damn smart when it comes to this stuff and great to do business with
PostPosted: Sat Aug 21, 2010 3:52 am
Stock trans?
PostPosted: Sat Aug 21, 2010 10:13 am
Hey gmoney. If you are near enough to Auburn, WA I have one out of a '75 you can have for free if you pick it up.
Eric Q.
My build thread.
PostPosted: Tue Aug 31, 2010 9:10 pm
sorry guys been real busy as of late, yes its the stock trans and im pretty far im up in calgary canada
PostPosted: Wed Sep 01, 2010 7:58 am
There's a guy on the IsuzuPup.com forum who has an S10 that he put a P'up diesel into. He found a Buick driveshaft that fit the output shaft of the P'up transmission, and bolted right up to the S10 rear end. I'm not sure if he has a short or long bed, but I'll see if I can find that post and link it here.
Update: It's in our "Parts" section, which isn't "public". So here's the quote:
Youngcummins wrote:
ok well it turns out that a drive shaft out of a 79 buick regal with a th350 fit PERFECT!!
He has a regular cab, long bed S10. My guess is you'd have to have the driveshaft shortened, but that wouldn't be hard.
