It is currently Mon May 25, 2026 7:37 am
 Post subject: Leaf springs
PostPosted: Wed Sep 01, 2010 4:08 pm
My leaf springs on my driver side is pretty saggy. Any ideas on where I can get some new ones or if I could get them re arched?
 Post subject: Re: Leaf springs
PostPosted: Wed Sep 01, 2010 7:05 pm
Have a spring/suspension shop near you? Could get new ones made!
PostPosted: Thu Sep 02, 2010 5:18 pm
An add-a-leaf or i rebuilt mine using Trooper springs there are lots of options and you are at the right place to get them. Good luck.
PostPosted: Thu Oct 07, 2010 9:30 pm
if you have some sag, but not total arch droop, then you might benefit from a set of monroe load leveling shocks. i had the sag to the point of sitting on the overload leaf, but not anymore. at best, it's a temp fix, but it does distribute the weight of the truck a bit better than what i had on there before. (monroe-matics)
Figuarus wrote:
well, it took me 5 months, but i finally got the sag problem under control (as of the moment)
i ended up going with a set of monroe sensa-trac load leveling shock absorbers - P/N 58567.
at the moment, the springs are arched like they were when i bought the truck. At the most, it's a temporary fix, but it definitely helps with the sag and ride quality. just wanted to update this situation. now, onto the other issues!
:lol:
