It is currently Mon May 25, 2026 10:53 am
 Post subject: Toyota Conversion Width
PostPosted: Thu Aug 26, 2010 8:25 am
I was reading on the Toyota conversion thread and was interested in changing my 75 over to that conversion. But...if it adds width to the front end I cant do it due to tire and fender clearance. I know the question was asked but didnt see the answer. Is it wider than the stock drum setup I have. Thanks
[img][IMG]http://i962.photobucket.com/albums/ae108/FedMoore/thIMG_0358.jpg[/img][/img]
PostPosted: Thu Aug 26, 2010 10:43 am
Yes, I believe it is 1/4-1/2 per side, if i remember correctly...
PostPosted: Thu Aug 26, 2010 10:56 am
Thanks Mouse. I have lowered the front since you have seen it in March due to wheelies and it is real tight in the finder clearance. Holeshote Makes a wheel that is a 4" wheel that has a 2 7/8" backspacing I am going to put on it to try to tuck the front in just a bit more. I guess the old drums will have to do for a little while longer.
PostPosted: Thu Aug 26, 2010 11:19 am
I put a set of tubular a arms that take a pinto spindle just for the clearance issue on mine. Pulled the wheels in 1-1/4 inch per side, and lowered it 1 inch..
PostPosted: Thu Aug 26, 2010 11:37 am
That sounds like what Im looking for Terry. Can you give me some mor info on where you purchased the a arms and maybe some pics. Sounds like just the ticket.
PostPosted: Thu Aug 26, 2010 7:06 pm
viewtopic.php?f=7&t=22862
PostPosted: Mon Aug 30, 2010 6:38 am
Thanks! 8)
