It is currently Mon May 25, 2026 11:20 pm
 Post subject: Master cyl upgrades?
PostPosted: Wed Apr 07, 2010 6:37 pm
Hi everybody, I have a master cylinder and power booster question. My V8 powered truck ( missing dont know why) was bought without either, so my question is does anything fit out of an S-10 or other car to replace my missing ones??. Over $150 for both online. any cheaper ideas :D thx
Marty
 Post subject: Re: Master cyl upgrades?
PostPosted: Wed Apr 07, 2010 11:21 pm
find a good set at a junk yard or a used parts store for cheap but make sure there is a good seal between the master cylinder and booster and then with your v-8 conversion buy a different proportioning valve for the bigger brake set-up it will be cheaper all the way around as i found out just check for leaks around the master cylinder or booster paint to make sure its dry instead of paint chipping off from brake fluid leaking on it!
PostPosted: Wed Apr 07, 2010 11:22 pm
oh yea do not detach or take the master cylinder off to ensure the right seal between them both as a heads up or you'll have major problems as well.
PostPosted: Thu Apr 08, 2010 10:17 pm
viewtopic.php?f=7&t=17500&p=129657&hilit=master+cylinder#p129657
PostPosted: Sun Apr 11, 2010 10:16 am
94 Jeep Cherokee and is aluminum my setup is run with the front to rear lines reversed and no proportioning valve but this will work as a good replacement and still use your prop. valve.
