It is currently Sat Jun 27, 2026 6:47 pm
 Post subject: brakes upgrade ?
PostPosted: Thu Jan 21, 2010 7:49 am
whats the deal on the bore size on the brakes what significance is that cause im gonna swap my brake booster out for a willwood unit but it has so many diff bore sizes any help would be great and thanx ahead of time
Epic Fabrication.
KAOS
 Post subject: Re: brakes upgrade ?
PostPosted: Thu Jan 21, 2010 12:16 pm
Bigger bore pushes more fluid, but the pedal will feel spongy. Too small a bore, the pedal will feel really hard, but you more or less roll to a stop...
PostPosted: Thu Jan 21, 2010 12:42 pm
its all in surface area the bigger the piston the more volume but takes more leg to make it work (or a booster) the smaller bore has more pressure but less volume per stroke.
Confused yet?
When i first built my truck as well as several others i adapted a Pinto master cyl (Manuel brakes) for the brakes (small bore) and had plenty of brake pressure and volume per stroke .
Something to remember is small bore/big piston = less pedal pressure
big bore/small piston = more pedal pressure
PostPosted: Wed Jan 27, 2010 4:39 pm
ok well imma try and make this easy for me..whats a 2000 s10 run far as brake bore in the master cyclinder
Epic Fabrication.
KAOS
